How to Reconfigure a Wi-Fi Connection and Forget the Network on an Android Phone
While trying to review dash cam footage in the Garmin Drive App you may get the following message,
"To improve connection stability we need to reconfigure this Wi-Fi connection. Go to your Android Wi-Fi settings, and 'Forget' the (specified) network":
 Garmin Drive App improve connection stability error
To resolve this on your Android phone:
Note: These steps will vary depending on the phone model and OS combination
1. Touch Apps
    • Skip this on some phones
Apps icon with red box around it
2. Touch Settings
Settings icon with red icon around it
3. Touch Connections
Red box around Connections under Settings
4. Slide the switch to the right to turn on Wi-Fi if it's off, then touch Wi-Fi
Red box around Wi-Fi option under Connections
5. Touch the menu icon (3 dots)
Red box around three menu dots under Wi-Fi
6. Touch Advanced
Red box around Advanced under three dot menu
7. Touch Manage networks
 Red box around Manage networks under Wi-Fi
8. Under Saved Networks, touch the network you want to delete
Saved Networks under Manage Network
9. Touch Forget
Red box around Forget Network
The network is now deleted. Return to the Garmin Drive App to set up the Wi-Fi connection.
