Canceling an inReach Subscription Service Plan
Canceling the plan for your inReach® satellite communicator is immediate and a good option if the device will be stored for more than a year, or to prepare the device for a transfer of ownership. If you only need to suspend your plan, see Related
IMPORTANT: Canceling or suspending service will disable SOS and all inReach communication features.
Why Are You Wanting to Cancel Your Plan?
  • Are you a seasonal user?
    Consider switching to an Enabled plan or suspending your plan to reduce or eliminate your monthly service costs without canceling.
    For more details, see - inReach Consumer Enabled Plan vs. Suspended Plan.
  • Are you selling or giving away your device?
    Be sure to cancel your service and reset your device for the new owner/user. Resetting is typically found under Settings/Setup > Recovery/Restore.
    If you are replacing your inReach device, you can transfer the existing service to your replacement instead of canceling. For steps, see - Transferring Existing inReach Service to Another inReach Device.
If there is another reason and you would like to discuss your options to avoid service termination, contact Support. To continue canceling your service, select an option below and follow the steps.
Canceling Service for an inReach Satellite Communicator
NOTE: Canceling an Enabled, Essential, Standard or Premium plan is effective immediately and any remaining prepayment for the current bill cycle is pro-rated and credited accordingly within 24 hours. If you choose to activate again later, you will be assessed another activation fee. If you are preparing a device for a transfer of ownership, but plan on activating a different device later, contact Garmin Services Billing to discuss your options. The process for canceling your service is the same whether the inReach device is suspended or active. Suspending a device does not allow for it to be transferred to another account.
Canceling inReach Service Using the Garmin Website
  1. Log in to the Subscription Portal.
    • When signed into your account at Garmin.com, the Subscription Portal can also be accessed by selecting Account Profile Icon in the top right corner of the page, then Account. From there select SUBSCRIPTIONS & SERVICE PLANS on the left of the page.
  2. Select MANAGE on the subscription you want to cancel.
    Manage Button
  3. Select CANCEL PLAN.
    Cancel Button
  4. If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch your subscription to inReach Enabled to keep the device active in case of an emergency for a low monthly fee, or suspend your subscription for up to 12 months to avoid a reactivation fee.
    If you still wish to cancel, select CONTINUE WITH CANCEL.
    NOTE: If you wish to suspend your subscription or switch it to inReach Enabled, but are not prompted with an option to do so, select BACK and choose the option to CHANGE PLAN instead.
    Garmin Website inReach Cancel
  5. Select CANCEL IMMEDIATELY when prompted to finalize canceling service.
Canceling inReach Service Using the Garmin Messenger™ App
NOTE: The following process only works with Garmin Messenger app compatible inReach devices.
  1. Open the Garmin Messenger app.
  2. Select Device.
  3. Select your current plan type below the picture of your inReach device.
    inReach Mini 2 Connected With Premium Plan
  4. Select Cancel Plan.
    Plan Options in Garmin Messenger
  5. If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch your subscription to inReach Enabled to keep the device active in case of an emergency for a low monthly fee, or suspend your subscription for up to 12 months to avoid a reactivation fee.
    Garmin Messenger Cancel Plan
  6. Select CANCEL IMMEDIATELY when prompted to finalize canceling service.
    Garmin Messenger Cancel Immediately
Canceling inReach Service Using the Earthmate® App
NOTE: The following process only works with Earthmate app compatible inReach devices..
  1. Open the Earthmate app.
  2. Select Three horizontal lines (Android™) or More (iPhone®/iPad®).
  3. Select My inReach.
  4. Select Manage Subscription.
    My inReach Page With Manage Subscription Option
  5. Select Cancel Plan.
    Earthmate Manage Subscription Page
  6. If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch your subscription to inReach Enabled to keep the device active in case of an emergency for a low monthly fee, or suspend your subscription for up to 12 months to avoid a reactivation fee.
    Earthmate Cancel
  7. Select CANCEL IMMEDIATELY when prompted to finalize canceling service.
    Earthmate Cancel Immediately
Sending a Cancelation Request to Garmin Services Billing
Send your request to GarminServicesBilling@garmin.com. The request must state that you wish to cancel service, and also include the following:
  • Email address the service is under.
  • Billing address of the credit card used on the account.
  • IMEI number of the device.
Failure to submit the proper information can delay implementation of your cancelation.
Requests of cancelation will be processed and become effective within 2 business days of submission. Garmin is closed on weekends and holidays.
What Happens if I Cancel?
Canceling takes effect immediately and puts the inReach device in a "deactivated" state where it no longer functions on the Iridium satellite network. Any saved account data will still be available after canceling. If there is no activity on your Garmin account across all our sites and services for at least 2 years, your account may be deleted. For more details, see - Inactive Account Deletion. Devices have to be activated again in order to function on the Iridium satellite network and would incur an activation fee. If you want to continue on a inReach service plan again later, choose to suspend instead.
Existing Annual Plan Users1
inReach Annual subscription plans are no longer available for new inReach activations, and you will not be able to return to your previous plan once it has been canceled. For more details on our new plans, see - .
When canceling an Annual plan, at the option of Garmin, your account will either: (1) be billed at the time of cancelation for the remaining amounts due on your service plan -or- (2) be billed for an amount equal to the fees for the remaining term of the service plan at the lowest available rate.
During the cancelation process you will be informed of any approximate costs due to you. If you miss this, our billing team can provide an estimation, or a final amount once the current billing cycle is finished.
If you decide you want to activate again later, you will be assessed another activation fee.
Existing Freedom Plan Users1
inReach Freedom subscription plans are no longer available for new inReach activations, and you will not be able to return to your previous plan once it has been canceled.
If you choose to cancel service on a Freedom plan and then choose to activate again later, you will be assessed a new activation fee when selecting a new plan. For more details on our new plans, see - .
1 As of September 18, 2024, both the Annual and Freedom versions of Safety, Recreation, and Expedition plans are no longer available for purchase. Existing Freedom plan users will be automatically migrated into the closest equivalent new, active plan upon reaching their annual renewal date. Existing Annual plan users can remain in their plan until they change to one of our newer plan options or cancel their subscription. If you are unsure which plan you are on, you can check under Current Plan on the Home tab of your Garmin Explore web account.
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
Related
