Customizing a Chartplotters Startup Image
Select chartplotters1 are capable of adding a customized image on the startup screen. Follow the steps:
Insert a micro/SD card that contains the image into the chartplotter. Select Options > Settings > System > Sounds and Display > Startup Image > Select Image choose the micro/SD card slot, select the image, and Set as Startup Image.
NOTE: The file type for the image can be .jpeg, .png, or .bmp and can be located anywhere on the micro/SD card.
For the best fit for the startup images, use an image that has the following dimensions, in pixels:
Display Resolution Chart
1The following GPSMAP series are compatible with this feature: 7x2 / 9x2,  7x2 / 9x2 Plus, 7x3 / 9x3, 1xx2 / 12x2, 12x3, 74xx / 76xx, 84xx / 86xx.
