Select the following link to download the app: Amazon Music Connect IQ app.
If prompted, sign in to your Garmin account.
Select your device to download the app.
Acknowledge any app permission requests.
The message should indicate that the app will be installed during the next sync. If this does not occur automatically, below are options to sync your device:
To sync via Bluetooth: Be in range of your paired smartphone, then press and hold the key to access the Controls Menu. Select
to sync.
To sync via Wi-Fi: Be in range of your Wi-Fi network, then press and hold the key to access the Controls Menu. Select
to sync.
To sync using Garmin Express: Connect the device to a computer using the charging cable. Open Garmin Express. The sync will automatically occur once the device is detected.
Once the sync is complete, the Amazon Music app will be installed on your watch. You are ready to move to Step 2 below.
