Garmin Swim Battery Replacement
Based on typical use, the battery should last approximately one year. Battery life depends on how much time the watch spends in the various modes (swimming, sleep mode, etc.) and also how frequently certain functions are used, like the backlight.
Changing the Battery on the Garmin Swim:
NOTE: Use extreme care when replacing the battery. Do not damage the battery contacts, battery compartment, or O-ring. Damage can compromise the water resistance of the device.
  1. Wrap the end of a small flat screwdriver Number one with tape. The tape protects the watch exterior, O-ring, and battery compartment from damage.
    open battery door with screwdriver
  2. Carefully pry the battery cover Number twooff.
  3. Remove the battery Number three.
  4. Make sure the O-ring Number four is not damaged and that it is completely seated in the lowest groove.
    battery and battery door
  5. Tip the new battery under the two plastic tabs Number five, and press it into place. Do not damage the contacts Number six.
    pressing battery into compartment example
For more details please refer to the Garmin Swim battery replacement instructional video.
