Using the Xero Laser Locate with a Compatible Handheld
In order to use the Xero Laser Locate feature on a compatible handheld device you will first need to make sure the latest software updatesare installed.
Also, Broadcast Mode will need to be enabled on the Xero. See the owner's manual for instructions.
 After checking that the unit is up to date and enabling broadcast mode on the Xero, the Xero Location application will need to be added to the main menu of the device.
To add the Xero Locations app to an Oregon 700 series device:
  1. Press the Power button once to open the app drawer
  2. Touch
  3. Touch Setup Drawer
  4. Touch the + icon in the upper right hand corner
  5. Touch Applications
  6. Touch Xero Locations
To add the Xero Locations app to a Rino 750 or 755t click one of the links below:
Customizing the main menu
Customizing the app drawer
To use the Xero Locations app, simply open the app from the main menu or app drawer of your compatible device after firing your bow. Arrow locations should automatically appear as long as the Broadcast Mode has been enabled on the Xero.
Related
