Removing a Device from Garmin Connect Mobile
There may be situations where you would like to remove a device from Garmin Connect Mobile - a new device purchase, app troubleshooting or removing an old device. Depending on the device, you may also need to remove it from the Bluetooth settings on the phone.
Android:
- Open the Garmin Connect Mobile app
- Touch the Menu button
- Touch Garmin Devices
- Press and Hold the device to remove.
- Touch Remove Device when prompted
Remove from Bluetooth settings: (only necessary with certain devices)
- Open Phone Settings
- Touch Bluetooth
- Touch the Gear icon
next to the previously paired device(s)
- Touch Unpair
iOS:
- Touch the More button
- Select the device you wish to remove
- Touch
in the top right corner
- Touch Remove
Remove from Bluetooth:
- Touch Bluetooth
- Touch the Info icon
- Touch Forget this Device, and press the Forget Device to confirm
Windows: :
- Touch Devices
- Touch Bluetooth
- Locate the device, and touch on the left side of the screen next to the name
- Touch Delete
Occasionally you may need to remove the device from the Garmin Connect website in order for it to be completely removed. To remove a device from Garmin Connect:
- Log in to your account at http://garminconnect.com.
- Click on the Hamburger Menu
- Click on Devices in the side menu
- Click on the Garmin device to be removed
- Click on the Gear icon
(top right)
- Select Remove from the drop-down menu
Your device should now be completely removed from your account
