Displaying NMEA 2000 Data on a quatix® Watch Series
The GNT™ 10 NMEA Transceiver provides the ability to transmit NMEA 2000 data, like boat speed, depth, true wind angle, etc., over the wireless ANT® network to a quatix® series smartwatch using the GNT 10 app from the Connect IQ™ store. To view a full list of NMEA 2000 PGN's that will transmit from the GNT 10, view the device's installation manual.
NOTE: Chartplotters with built-in wireless do not require the use of a GNT 10 and would instead use the built-in Boat Data app.
To allow the quatix to communicate with the chartplotter, a GNT 10 NMEA Transceiver will need to be installed into the NMEA 2000 network. For information about connecting the GNT 10 to the NMEA 2000 network, refer to the Installation Instructions.
To pair the quatix® 1 watch with the GNT 10
  1. Bring the quatix within range (3 m) of the GNT 10
  2. Select the blue key
  3. Select Setup > ANT Sensor
  4. Select the GNT 10
  5. Select New Search
When the GNT 10 is paired with the quatix, the sensor status changes from Searching to Connected. Sensor data appears in the data page loop or a customer data field.
To stream NMEA 2000 data through the GNT 10 to the quatix:
  1. Select the blue key
  2. Select Setup > ANT Sensor > GNT > On
  3. Select the back key twice
  4. Select Stream N2K to begin streaming NMEA 2000 data
To stop streaming NMEA 2000 data, select the blue key, and select Stop N2K.
To pair the quatix® 3 watch | quatix® 5 watch with the GNT 10
To pair the quatix watch with the GNT 10, install the GNT 10 Connect IQ application. For instructions to install the GNT 10 application, see related content.
Once the GNT 10 application is installed, pair the quatix watch with the GNT 10:
  1. Bring the quatix watch within range (3 m) of the GNT 10
  2. Open the GNT 10 application on the quatix
  3. The quatix watch will search for the GNT 10 and when paired, "Connected" will appear
The quatix watch will stream NMEA 2000 data automatically once the watch and GNT 10 are connected.
To pair the quatix® 7 watch to a GNT 10
Before streaming data fields from a compatible GNT 10 transceiver to a quatix watch, the GNT 10 app (Connect IQ Features) must be downloaded.
  1. From the watch face, select START > GNT 10
  2. Bring the quatix watch within 3 m (10 ft.) of the transceiver
  3. Set the transceiver to enter pairing mode
    See the transceiver owner's manual for more information
  4. If necessary, on the quatix watch select START to modify a data page
The quatix watch displays up to three data fields per page, and up to six pages of data. After the devices are paired, they connect automatically when they are turned on, within range, and the app is open on the watch.
TIP: To pair the quatix watch with another transceiver, from the GNT 10 app, hold MENU and select Pair New.
Related
