How Do I Remove My Varia From the Varia App?
There may be situations that require your Varia™ bike radar or headlight to be removed from the Varia™ App, such as app troubleshooting, returning the device, transferring ownership, or removing an old device. Follow the steps below to complete the process.
Remove the Varia From the App
  1. Open the Varia App.
  2. Select three blue dots stacked vertically (top right corner).
  3. Select Devices.
  4. Select your Varia device.
  5. Select three blue dots stacked vertically (top right corner).
  6. Select Remove Device.
  7. Confirm you want to remove the device.
The Varia should now be removed from the Varia App. Follow the next steps to completely remove the Varia from your mobile device.
Remove the Varia From Your Device Bluetooth Settings
The steps below will need to be completed in order to successfully remove the Varia from your mobile device. Select your mobile operating system below for details.
Android
NOTE: The steps below are fit to work for a majority of models. If you need specific steps please contact your phone manufacturer.
  1. Open the Android Settings app.
  2. Select Connections.
  3. Select Bluetooth.
  4. Locate the name of your Varia under Paired Devices.
  5. Select gear icon.
  6. Select Unpair.
  7. Confirm you want to unpair.
iOS
  1. Open the iOS Settings app.
  2. Select Bluetooth.
  3. Locate the name of your Varia.
  4. Select blue lowercase i in a circle icon (right).
  5. Select Forget This Device.
  6. Confirm you want to forget the device.
Related
