Viewing inReach to inReach Message Locations in the Earthmate App
To view inReach® to inReach handheld message locations on the map of the Earthmate® app, the following requirements must be met.
inReach to inReach handheld message locations can also be viewed on most inReach devices.1
IMPORTANT: The inReach device must have an active subscription (see - ) and be paired to the Earthmate app. For pairing steps, see Related.
Requirements for Message Locations
Both Include Location and Show Messages must be enabled in the Earthmate app and messages must be sent to the user's inReach address.
Including Location With Messages
The Include Location setting described below will only affect brand new message threads. When replying to a previous message, make sure to check if location is enabled or disabled
for that specific message thread.
Open the Earthmate app.
Select
(Android™) or More (iPhone®/iPad®).
Select Settings (Android) or Options (iPhone/iPad).
Select Messages.
Enable Include Location.
Showing Messages on the Map
Select
Select Map.
Enable Show Messages.
Finding Your inReach Address
Each inReach user account is assigned an inReach address (example@inreach.garmin.com) at the moment the account is created. The inReach address only works for inReach-to-inReach communication. Messages sent to an inReach address from devices other than inReach devices will not be delivered.
To obtain the inReach address:
Log in to the inReach account at explore.garmin.com.
Select Account.
The inReach address can be found in the My Info section in the left-hand column.
The inReach address can also be found in the Settings menu on the inReach product under About This Device.
Viewing Message Locations
Go to Messages.
Android: From the Map page, touch
or select
> Messages.
iPhone/iPad: From the Map page, select Messages.
Select a message thread.
Select a message that includes location (indicated by
Select VIEW (Android) or tap on
in the map preview (iPhone/iPad).
The location of the message will be displayed on a map in Earthmate, indicated by on the map.
1 Message locations cannot be viewed on inReach for Smartphones. The inReach Mini and inReach SE® satellite communicators do not support detailed mapping, but can still display coordinates for message locations.
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
