Changing the data fields on the Edge 800
The Edge 800 does allow for customization of data fields on specific pages. The pages that can be customized are: Timer Pages, Course Page, Workout Page, Elevation Profile Page and Map Page.
To change data fields on the Edge 800:
- Power on device
- Select MENU
- Select Settings (wrench icon)
- Select Bike Settings
- Select Training Pages
Virtual Partner can only be turned on or off. The data fields can be changed on each of the other selections.
To change the data fields on the Timer Pages:
- Select Timer Pages (after step 5 from first number list)
- Select User Defined1
- Select your preferred training page
- Select desired number of fields (10 max)
- Touch the green checkmark
- Touch a data field to change2
- Repeat step 6 for all fields
- Touch Back (arrow pointing to left) twice to return to Timer Pages
- Repeat steps 3-7 as needed for each page
To change the data fields on the Map page:
- Select Map (after step 5 from first number list)
- Select the number of data fields
- Select a data field to change2
- Repeat step 3 for other data field
- Touch Back (arrow pointing to left) to return to Training Pages
To change the data fields on the Elevation page:
- Select Elevation (after step 5 from first number list)
- Select On to show Elevation in training loop
To change the data fields on the Lap Summary page:
- Select Lap Summary (after step 5 from first number list)
- Select the number of data fields (4 max)
- Repeat step 5 for all fields
The Edge 800 will now display the desired data fields.
1The Course and Workout Timer pages only show up when doing a course or workout. If enabled, an added Training page will show for a course/workout.
2Refer to owner’s manual under Customizing Your Data Fields for a list and description of all the various data fields.
