Steps to Manually Upload Activity Data From a Marine Handheld to a Garmin Connect™ Account
Garmin® Marine handheld devices that connect via USB in mass storage mode1 can import activities into your Garmin Connect™ account.
Manually Uploading Activities to Garmin Connect
  1. Connect the device to a computer using a USB cable
  2. Sign in to Garmin Connect
  3. Select in the top right corner of the page
  4. Select Import Data
  5. Select Browse
  6. Locate and select activity file
  7. Select Import Data
Activities uploaded will display in the Garmin Connect account.
NOTE: Garmin Connect supports the following file extensions FIT, GPX, and TCX files. The file must include time information for a GPX file to successfully upload to Garmin Connect. Suppose you are exporting activities from Strava with the intent of importing them to Garmin Connect. In that case, you will need to export the activities as single activities rather than a bulk export (see Strava Support - Exporting your Data and Bulk Export).
Windows PC
  1. Plug the device into a computer
  2. Click Windows key + E
  3. Click This PC (Windows 10 only)
  4. Double-click the Garmin device drive:
    Windows 10
    Windows 7/8
    Devices and Drives screen Windows
    Removeable Storage Windows
  5. Double-click the Garmin folder
  6. Double-click the Activities folder
Mac
  1. Plug the device into the computer
  2. Open Finder
  3. Click Go in the menu bar
  4. Click Computer
  5. Double-click the Garmin device drive
    Device Drive Mac
  6. Double-click the Garmin folder
  7. Double-click the Activities folder
1 For a list of mass storage devices, see Related Content. To locate the activity files on a Garmin mass storage device, select your computer's operating system below:
Related
