Updating InReach SE+/Explorer+ Firmware Without an Active Device or Explore Account
Follow the instructions below to download and install the inReach® Sync application which will update the firmware on the inactive inReach device to the latest version.
IMPORTANT
  • If you sync when you do not have an active subscription for the inReach handheld, only the firmware (device software) will be updated. An active subscription is required to sync contacts, waypoints, routes, etc., as well for using the inReach services, such as messaging. The inReach handheld must be ACTIVE for the SOS button to function.
  • If the inReach device has been added to an account but is not active on a subscription plan or there is no active subscription, inReach Sync may give an error, such as 'Unknown device'. The inReach device either needs to be removed from the account, activated on a subscription plan, or put into Firmware Update Mode to continue.
    To enable Firmware Update Mode, see below:
    1. Disconnect the inReach from the computer and power off the inReach handheld.
    2. Press and hold XDown, and Power simultaneously.
    3. The device will power on into Firmware Update Mode.
    4. Connect your device to the computer.
    5. Open inReach Sync and test to confirm that the issue has been resolved.
      • NOTE: When inReach Sync recognizes your device, the app will display a message that the firmware on the device is corrupt. Click Yes to proceed with the firmware update and Sync.
Installing the inReach Sync Program
  1. Download the inReach Sync program:
  2. Locate and run the downloaded file.
  3. Follow the on-screen installation steps.
  4. Launch inReach Sync.
  5. Plug in your inReach SE®+ or inReach Explorer®+ handheld.
  6. Turn on the inReach handheld.
  7. Wait for inReach Sync to apply updates.
Related
