Display Latitude and Longitude on Map Page
The latitude and longitude of the current position of the device can be displayed in a data field on the Map page. The instructions below will walk you through this process.
- Press Menu on the Map page
- Select Data Fields
- Press Enter on 3 Data Fields
- For GPSMAP® 60Cx, 60CSx, 76Cx, or 76CSx handheld users, you may also select 2 Wide Data Fields or 1 Wide Data Field
- Press Menu
- Press Enter on Change Data Fields
- Select a Wide Data Field
- Press Enter on one of the Location fields
You will notice there will be two different Location fields to choose from. Location (lat/lon) will display the location in the hddd mm ss.s position format. Location (selected) displays the location in the position format of the device.
