My GPSMAP 66, 67, 79, or 86 Series is in the Wrong Language
If your GPSMAP® 66, 67, 79, or 86 series handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
  1. Press the MENU key twice to open the main menu.
  2. Select Wrench and Screwdriver.
  3. Select Gear Wheels.
  4. Scroll to and select the second item in the menu.
  5. Scroll to and select the desired language.
Handhelds With inReach
You may receive a prompt to activate before being able to access other settings on the GPSMAP 66i, 86i, or 86sci. If this occurs, select the option at the very bottom of the screen to skip activation, then proceed with the steps above. Activation can be completed later from the main menu.
inReach Activation Prompt
Related
