Hold
MENU.
Select Dive Setup.
Select Auto Dive.
Select an option:
Mode: Choose for auto dive to use either the last dive or the last scuba type accessed on the watch.
Snooze: Choose to temporarily disable auto dive for 1 hour or until tomorrow. Snoozing until tomorrow will count down until midnight. After the snooze timer ends, auto dive will automatically reengage. If you have snoozed auto dive, you can also choose to end the snooze early from this menu.
How Do I Prevent My Dive Computer From Going Into Dive Mode After Rapid Descent in Altitude?
Garmin® dive computers are designed to initiate a dive activity when the device notices a significant change in pressure. This can happen when sky diving or when rapidly descending in a plane among other circumstances. When this happens the watch will be stuck in dive mode. To prevent this, we recommend starting an activity on the device, powering off the device, or adjusting your auto dive settings prior to beginning an activity that can cause a rapid change in pressure.
Adjusting Auto Dive Settings
Some dive computers offer the ability to snooze or turn off the auto dive setting on the device. If you know that you are going to be in a situation when the watch might enter a dive, such as swimming without starting a swim activity or flying in a plane, you may want to adjust the auto dive setting to avoid the device erroneously starting a dive.
Select one of the dropdowns below for specific steps to adjust your auto dive settings.
Hold
MENU.
Select Watch Settings.
Select System.
Select Depth Sensor.
Select an option:
Auto Dive: Choose for auto dive to use either the last dive or to turn off the auto dive feature.
