Reporting Outdoor Map Errors
Garmin's map data is gathered through a number of different sources including local governments, principalities, etc. There may be an occasion where something is not reported correctly or was not able to be changed in time for the new version of mapping to be released.
We have provided an Error Report Form on our website that allows you to submit any findings regarding missing or incomplete locations or streets on the map. Be as descriptive as possible when completing the error report form.
Examples of Map Errors
Point of interest has moved or no longer exist
Device routing off of the road/trail (i.e. the path of road/trail is mapped incorrectly)
Map feature improperly named/numbered (roads/trails, water features, landscape features, etc.)
The coverage of roads and trails may vary between map products.
Reporting Errors for Maps Not Listed in the Error Report Form
When it comes to the following products, apps, and websites, the process used to report map errors is detailed below.
Garmin Explore™ website
Aerial satellite imagery is provided by Google. If blurred satellite imagery exists, it may be at the request of a government agency. Outdated satellite imagery can be reported directly to Google: Google Maps Help - Report data or content errors on Google Maps.
MapShare™ webpages
Garmin Explore app
Map errors can be reported directly within the Garmin Explore app: Reporting Map Errors in the Garmin Explore App.
Earthmate® app
Mapping on the inReach Explorer®+ satellite communicator
- DeLorme® Atlas & Gazetteer Paper Maps
Reporting Map Errors for These Products, Apps, and Websites
Go to the Error Report Form.
Leave the Garmin Device field blank.
Select Map Product, then scroll down and select Other Map - Not Listed at the end of the drop down list.
Type the name of the map/website/app in the Other Map field.
Add details in the Error Location Information section and complete all other required fields (marked with *).
Be as descriptive as possible and attach any image files that show the error.
