I Am Unable to Set Up the ECG App After Updating My Device Software
If you recently updated the software on your Garmin ECG app compatible smartwatch, but do not see the option to set up this feature in the Garmin Connect™ app, we suggest the following troubleshooting:
Ensure you have a compatible Garmin device with the most up to date software. See What Garmin Watches Have the ECG App? for more information.
Ensure you are in a compatible region. See Garmin ECG App Region Compatibility for more information.
It may take up to 24 hours for ECG app set up to appear in your Garmin Connect app.
If you do not see a Set Up ECG prompt after 24 hours, you can do the following:
Access the menu by selecting More (bottom right).
Select Garmin Devices.
Select your device.
Select Finish Set Up.
Select Set Up ECG app.
Follow the onscreen instructions to complete set up.
