Changing Which Page Loads When Powering on an Outdoor Handheld
By default, most outdoor handhelds will load to either the main menu or the map page once powered on. If you wish to change which page the handheld loads to, this can be controlled on certain handheld devices by changing the page sequence. Whichever page is placed at the top of the list will be the page that loads when the handheld is powered on.
You can also view and cycle through the items in the page sequence at any time by pressing the Page or Quit/Back keys.
eTrex® 10, 20, 20x, 22x, 30, 30x, and 32x Outdoor Handhelds
Press MENU twice to access the main menu.
Select Setup > Page Sequence.
Select a page.
If you wish to add a page, select Add Page.
Note that adding an item to the page sequence will remove it from the main menu.
Select Move.
If you wish to remove a page, select Remove.
Move the page up or down in the list.
Press the Thumb Stick™ controller.
GPSMAP® 62, 62s, 62st, 62sc, 62stc, 64, 64s, 64sc, 64st, 64x, 64sx, 64csx, 65, and 65s Outdoor Handhelds
Select a page.
Select Move.
Select ENTER.
GPSMAP 66i, 66s, 66sr, 66st, 67, 67i, 79s, 79sc, 86i, 86s, 86sc, and 86sci Outdoor Handhelds
Select Setup > Menus > Page Sequence > Edit Page Sequence.
Select a page.
Select Move.
Select ENTER.
Rino® 700 Outdoor Handheld
Press
Select a page.
Select Move.
Press the Thumb Stick controller.
