No Compatible Devices Found in the ActiveCaptain® App
If the ActiveCaptain® app is not pairing with a Garmin device, ensure the following:
Check the compatibility of your device. Compatible devices are listed below:
STRIKER™ Plus 7 fishfinder | STRIKER™ Plus 9 fishfinder | STRIKER™ VIVID 7 fishfinder | STRIKER™ VIVID 9 fishfinder
ECHOMAP™ Plus combo | ECHOMAP™ Ultra combo | ECHOMAP™ UHD combo
ECHOMAP™ 50s combo |ECHOMAP™ 70s combo |ECHOMAP™ 50dv combo | ECHOMAP™ 70dv combo
GPSMAP® 8x0 chartplotter | GPSMAP® 10x0 chartplotter
GPSMAP® 10x2 chartplotter | GPSMAP® 12x2 chartplotter (Touch, Plus )
GPSMAP® 5x7 chartplotter | GPSMAP® 7x1 chartplotter
GPSMAP® 7x2 chartplotter | GPSMAP® 9x2 chartplotter
GPSMAP® 7x3 chartplotter | GPSMAP® 9x3 chartplotter | GPSMAP® 12x3 chartplotter | GPSMAP® 16x3 chartplotter
GPSMAP® 74xx chartplotter | GPSMAP® 76xx chartplotter
GPSMAP® 84xx chartplotter | GPSMAP® 86xx chartplotter
GPSMAP® 90xx chartplotter | GPSMAP® 92xx chartplotter
Force® Trolling Motor 50" | Force® Trolling Motor 57" | Force® Kraken Trolling Motor 63" | Force® Kraken Trolling Motor 75" | Force® Kraken Trolling Motor 90" | Force® Pro Trolling Motor 50" | Force® Pro Trolling Motor 57"
Ensure the Wi-Fi on the Garmin device is enabled.
For STRIKER™ fishfinders | ECHOMAP™ chartplotters
Select ActiveCaptain from the home screen
Select Wi-Fi Network
Ensure Wi-Fi is turned on
If desired, use the directional pad to change the Wi-Fi name and Password
Force® Series Trolling Motors
Handheld Remote for the Force Trolling Motor turned on
Set Wi-Fi of the Force to ActiveCaptain mode: Menu button - Settings - Trolling Motor - Wi-Fi - Mode - ActiveCaptain
Make sure to setup a Wi-Fi name and password from the Handheld Remote
Wi-Fi settings of the mobile device, connect to the Wi-Fi of the Force Trolling Motor
For GPSMAP® chartplotters
From the AV/Gauges and Controls menu, select ActiveCaptain
Verify the Garmin device software is up to date. For instructions on updating the software, see Related Content.
Close any apps that are running in the background on the smart device
Restart the smart device
Connect to the chartplotters Wi-Fi signal
