Garmin Hardware Diagnostic Tool Compatibility and Requirements
The Garmin Hardware Diagnostic Tool can be used to run diagnostics and determine part failures with certain Garmin products. You will need your Garmin account credentials to use this tool and you will be asked to sign into your account once the program is installed.
Where Can I Download the Tool?
You can download and install the tool from the following link:
Garmin Hardware Diagnostics Tool Download
Once you have downloaded the program, open the contents to begin the installation process. Note the following requirements to install the tool in the next section.
Minimum PC System Requirements
Windows 10 or newer
1 GB free disk space
USB-A interface
Compatible Products
The following products are compatible to use with this tool. This list is subject to change.
T 5 Dog Device
TT™ 15 Dog Device
T 5X Dog Collar
TT™ 15X Dog Collar
Alpha® T 20 Dog Collar
Alpha® TT 25 Dog Collar
My Device is Not Recognized by the Tool
If your Garmin device is not recognized by the tool, confirm it is on the compatibility list above. If it is, see the following for further assistance: Dog Collar Not Recognized by a Computer
