Changing Garmin Lock on an Automotive Device
When the Garmin Lock feature is set, the device marks its GPS position to establish a security location. The device can be unlocked using the PIN or by returning to the security location and allowing the device to pick up satellite signal.
Once the device is unlocked, you may change the PIN and/or security location.
To Change the Garmin Lock Settings:
- Turn the device on
- Touch Tools
- Touch Settings
- Touch Security
- Touch On/Off under Garmin Lock
Within this section you can add or change the PIN and security location.
