Pairing a Portable Handset (H1P) to a Cortex® Network
There are two possible ways to connect the Cortex™ H1P device to the system's network depending on the software installed on the H1P.
Applicable to all Software Versions
Tap the Menu icon at the screen or push the menu button | ![]() |
Tap the Wrench Tool at the left hand corner of the display | ![]() |
Select "Networks" | ![]() |
Select Wi-Fi | ![]() |
Tap "Hub" and Select the Cortex HUB | ![]() |
Enter the Wi-Fi password displayed at the QR code label of the Hub and tap "CONNECT" | ![]() |
The H1P unit is now connected to the Cortex HUB | ![]() |
Applicable as of Software version 1.4 or Higher
As of version 1.4, you are able to access the WiFi configuration from the WiFi icon at control bar
Tap the Wi-Fi Icon at the top menu bar | ![]() |
Tap the Wrench icon | ![]() |
Push "SELECT" in the Cortex Network window | ![]() |
The available SSID will show up above the SSID banner- find your device's SSID and tap on in and it will appear in the banner | ![]() |
Select the HUB network and enter the Wi-Fi password displayed at the QR code label of the Hub and tap "SELECT" | ![]() |
The select network will appear in the Cortex Network window, status "connected" | ![]() |
