Viewing more map data fields on a Garmin automotive device
Your automotive device has a map setting which allows you to view more data fields (speed, direction, time, elevation) when you are on the navigation screen. By default, there are only two data fields at the bottom of the screen, at least one of which is customizable.
If the More Data map setting is enabled, there will be four data fields which are customizable. Follow these steps to enable this setting on your device.
- Touch Tools
- Skip this step on some devices
- Touch Settings
- Touch Map
- Change the setting under Map Data Layout to More Data
- Touch OK to save the change
The device will now display more data fields on the navigation screen. Most of these data fields will be customizable.
