How to Set the Current Map Location to Somewhere Else on a Garmin Automotive Device
There may be times when you would like to see the map, and/or other points of interest, at a different point on the map from your current location. To do this, you will need to put your device in GPS Simulator mode, then select the desired location.
To Set Your Location at a New Position on the Map:
- Ensure there is no route active by touching Stop on the main menu
- Touch
Settings
- Touch Personal
- Touch Location
- Touch the switch next to Location to turn it off
- At the bottom of the screen, touch
to return to the main menu
- Touch View Map
- If a message appears that GPS Simulator is turned on for indoor use, touch OK
- Touch the map
- Drag your finger across the screen to move the map to the desired location
- Touch the desired map location
- Touch the icon
that appears
- Scroll down and touch Set Location
Once the new position is set, you will be able to view the map and search for POIs in that area.
To Set Your Location at an Entered Destination, Such as a POI or Address:
- Touch Where To from the home screen
- Locate the destination
- Touch the destination
- Touch the
info button
Tips:
- Touch the
and
buttons on the map screen to zoom in and out.
- Touch Save to save the location the arrow is pointing to.
- Touch Go! to simulate driving to the location.
- Turn the Location setting to On once you are ready to navigate real-time to a destination.
