You are viewing an article that is not available in your currently selected language. You can choose another one below.
Understanding the LED Colors on the Garmin Dash Cam Mini 3
The Garmin Dash Cam™ Mini 3 has status LED lights below the large save button and below 'Garmin' that displays different colors and patterns depending on the device status. Below is a breakdown of the different LED meanings. Some colors can have more than one meaning.
Green
  • The device is connected to a computer.
    • The computer will not provide enough power to pair the dash cam with the Garmin Drive app
  • The memory card is being formatted.
  • If stuck on this color while plugged into the vehicle, see Garmin Dash Cam Power Issues.
Dash Cam Mini 3 Green
Green (Solid) changes to Red (Solid)
  • While the device is connected to a computer, a different memory card is swapped with the installed one.  Resolution: format the desired memory card in the Dash Cam Mini 3 prior to connecting it to a computer.
    • To format power the device on while disconnected from the computer.
    • Hold the microphone (DC Mini Microphone) button along the bottom right for eight seconds.
    • The left LED light will turn green briefly and then red as recording begins.  The right LED light will turn red if the microphone is on or will be off if the microphone is off.
DCMini3_Recording
Slow Flashing Green
  • The device is booting.
 DCMini3_Booting
  • An update is being installed.
DCMini3_Update
Red
  • Video is recording.
DCMini3_Recording
  •  Audio is being recorded.
DCMini3_RecordingWithAudio
Flashing Red
  • A video is starting to be saved.  The animation will play for 2 seconds.
  • An incident has been detected.
DCMini3_SaveStarted
  • Saving video is in progress.  The animation will play for the duration of the save.
DCMini3_SaveInProgress
DCMini3_ParkingMode
Red with Flashing Yellow
DCMini3_LowOnSpace
See SD Memory Card Compatibility for Garmin Dash Cams to ensure a compatible card is being used.
See the Owner's Manual or Formatting a microSD card on a Garmin Dash Cam or in the Garmin Drive App for instructions to format the memory card.
Fast Flashing Yellow / Yellow and Green / Green and Green
  • There is a problem with the memory card or a memory card is not installed.
  • The memory card needs to be formatted.
    • The dash cam requires a properly-formatted memory card before it can complete its start-up sequence and begin recording.
    • To format hold the microphone (DC Mini Microphone) button along the bottom right for eight seconds.
DCMini3_ErrorSD
DCMini3_Error
See Flashing Yellow/Yellow and Green Light on a Garmin Dash Cam Mini 3, Garmin Dash Cam Mini 2, or Garmin Dash Cam Mini for troubleshooting steps.
Cyan
  • Voice Command
DCMini3_ASR
Blue/Flashing Blue and Red
  • The device is in Wi-Fi sharing mode.
DCMini3_WiF
  •  The device is in Bluetooth pairing mode (recording audio).
DCMini3_PairingWithAudio
  •  The device is in Bluetooth pairing mode (not recording audio).
DCMini3_Pairing
No Light
  • The camera is not connected to a power source.
  • See Garmin Dash Cam Power Issues if the Garmin Dash Cam is connected to power and has no light.
DCMini3_Off
