How Do I Manage the Alarms on My Lily Watch?
The Lily® smartwatch offers a vibration-only alarm and a snooze option.
  • The Lily - Classic Edition and Lily - Sport Edition can hold up to 8 alarms.
  • You can snooze an alarm for 10 minutes at a time; the duration of the snooze time cannot be modified.
How Do I Set Up an Alarm on the Lily Watch?
To set up an alarm for your Lily, you will need to use your Garmin Connect™ account. Select your preferred option below for instructions.
Garmin Connect App Instructions
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. Select your Lily watch.
  5. Select Alerts.
  6. Select Alarms.
  7. Set your alarm details.
  8. To save the changes, tap the back arrow in the top-left corner to return to the Device page.
The next time you sync your device, the alarm(s) will be sent to your Lily.
Garmin Connect Web Instructions
  1. Sign in to Garmin Connect.
  2. Select watch icon with blue dotin the top right corner.
  3. Select your Lily
  4. Select Alerts.
  5. Beneath Alarms, select Add Your First Alarm or Add New Alarm.
  6. Set your alarm details.
How Do I Enable or Disable an Alarm on the Lily Watch?
You can enable or disable an alarm from either Garmin Connect or your Lily watch. Select your preferred option below for instructions.
  1. Open the Garmin Connect App.
  5. Select Alerts.
  6. Select Alarms.
  7. Select Toggle On Blue Icon to turn an alarm on (blue) or off (gray).
The next time you sync your device, your changes will be sent to your Lily.
  1. Sign into Garmin Connect.
  3. Select your Lily.
  4. Select Alerts.
  5. Beneath Alarms, toggle on or off any alarm.
Lily Watch Instructions
  1. Press Hollow black circle to view the menu.
  2. Select Clock with hands at two and ten.
  3. Select Alarm clock with bells.
  4. Swipe to scroll through the alarms.
  5. Select an alarm to turn it on or off.
How Do I Delete an Alarm on the Lily Watch?
You can delete an alarm using Garmin Connect. Select your preferred option below for instructions.
  4. Select Alerts.
  5. Select Alarms.
  6. Select the alarm you wish to delete.
  7. Select Delete Alarm.
  4. Select Alerts.
  5. Beneath Alarms, select the trash can icon to the right of the alarm you wish to delete.
