My Varia RTL515 Will Not Turn On or Stay on After Charging the Battery
A Varia™ RTL515 radar tail light that will not turn on or will not stay on after charging the device may be the result of a defective micro USB port. If you are experiencing these symptoms and have ruled out the power cable being the issue, you can use our self-service exchange tool. There will be a repair fee to use this service for devices outside of their warranty period. Before you begin, you will need:
Serial Number
This is located on the device and on the box the device came in.
The email address associated with the device.
This should be the email address used to sign into Garmin Connect.
To begin the exchange process see the following link: Edge Self-Service Exchange Program
