Getting Started with the Approach Z30 Range Finder
If you are setting up an Approach® Z30 range finder for the first time, the following information will help you get the most out of the device.
Pairing the Approach Z30 Range Finder
Open the Garmin Golf app.
Select either
on an Android™ or More on iOS.
Select Garmin Devices.
Select Add Device.
Select Approach Z30.
Select Start.
Select Connect It.
Select Finish to complete the process.
