Why is the Unit of Measure Not Updating?
Select models may require you to adjust the unit of measure in one or more of the places mentioned below:
  • Garmin Connect™ account user settings.
  • Garmin Connect device settings.
  • On the Garmin device itself.
Adjusting the Unit of Measure:
NOTE: Some steps below will not be compatible with devices that use Real Time Settings.
Garmin Connect User Settings
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Settings.
  4. Select User Settings.
  5. Select Measurement Units.
  6. Select one of the following:
    • Statute
    • Metric
    • Statute UK
Garmin Connect Web
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Profile & Account (top right).
  3. Select Account Settings.
  4. Select Display Preferences.
    • Statute
    • Metric
    • Statute UK
Garmin Connect Device Settings
Garmin Connect App
  3. Select Garmin Devices.
  4. Select your device.
  5. Select one of the following:
    • General > Measurement Units
    • Device Settings > System
    • System > Format > Units
Garmin Connect Web
  2. Select Devices & Sync Status (top right).
  3. Select your Device.
  4. Select one of the following:
On the Device
NOTE: Steps below are generic and may vary with other models. For detailed instructions, refer to your owner's manual and search "Changing the Units of Measure".
  1. On the device, access the Settings menu.
  2. Select System.
  3. Select Units.
