Replaceable Bands for Outdoor Wearable Devices
If the band on your outdoor wearable device needs to be replaced because it has broken, torn or otherwise become unusable, replacements can be purchased on our website using the appropriate link below then select "Bands and Straps".
*Black silicone band is discontinued and not available on Garmin.com.
 Note: To find bands from Garmin.com:
  1. Hover over the "Products" menu at the top of the screen
  2. Select "Wearables"
  3. Select your device from the list*
  4. Click on "Accessories"
  5. Click on "Bands and Straps"
You will now see a list of compatible bands for your outdoor wearable device.
*If your device is not listed here you may need to use the search box located in the upper right-hand corner of the Garmin.com home page.
