Step 1: Make Sure Your Device Software Is up to Date
Plug your device into your computer using the USB cable.
Open Garmin Express program, then select your device.
If it says "You're up to date" your device is running the latest software.
If it says "You have items ready to install," select Install.
Unplug your device from the USB charging cable to allow the update to install. Plug back into the computer once complete.
Step 2: Remove the Connect IQ™ Content From Your Device
Select IQ Apps.
Select All from the drop-down menu (top right).
Find the feature that is causing the error on your device, then select the X to the right to remove it.
Select the back arrow at the top left, then select Sync to sync your device.
The Connect IQ content will no longer be on your device once the sync is complete.
Unplug your watch from your USB charging cable and verify the Connect IQ! error is no longer present.
Step 3: Reinstall the Connect IQ Content to Your Device
Connect the device to your computer using your USB charging cable.
Open Garmin Express, then select your device.
Select IQ Apps, then decide if you want to re-install the previous Connect IQ Content or install new content.
Install Previous Connect IQ Content:
Find the content and select
to send to device.
Install New Connect IQ Content:
Select
(bottom right) and a web browser will open to our Connect IQ store.
Review and accept terms, if required.
Grant permissions (if required) by selecting Allow.
Open Garmin Express program and select SYNC.
Unplug your device from the USB charging cable and verify the Connect IQ! error is no longer present.
