Enabling a Data Field Downloaded From Connect IQ to an Edge 130/130 Plus
After downloading and installing a data field from the Connect IQ™ Store, you will need to take extra steps to enable it for your Edge® 130 or Edge® 130 Plus cycling computer. You can add Connect IQ data fields to an existing data screen, or you can create a new data screen. Select an option below to reveal instructions.
NOTE: You can only use up to 10 Connect IQ Data Fields at one time.
On the Edge press and hold the up button to access the menu.
Select Ride Settings.
Select Data Pages.
Select the screen you would like to edit and select the Enter button.
Select the field you would like to change to the Connect IQ field.
Select Connect IQ.
Select the Connect IQ field you would like to add.
Select Data Pages.
Scroll down and select Add New.
Select Custom Data.
Select the data field layout you would like.
Select the Connect IQ field in the placement you would like.
