Editing Bullet Properties on a Garmin Watch with Applied Ballistics
Ensuring you have an accurate input of bullet properties into the Applied Ballistics app is critical to creating a proper shooting solution. To edit the bullet properties on a compatible Garmin® watch with Applied Ballistics follow the steps below. You can also create a profile using the Applied Ballistics Quantum™ app on your compatible smartphone or tablet (see related content for more information).
From the Applied Ballistics app, press
.Select Profile.
Select Bullet Properties.
Select an option:
To automatically enter bullet properties from the Applied Ballistics bullet database select Bullet Database, select your ballistic solver, the bullet caliber, manufacturer, bullet, and drag curve.
NOTE: You can select the caliber of your bullet by searching for a list of bullets within that caliber. Not all cartridge names match the bullet caliber. For example, a 300 Win Mag is a .308 caliber bullet.
To manually enter bullet properties if your bullet is not in the bullet database, press DOWN to scroll through the options and select the values to edit.
Ballistic Coefficient - the manufacturer's ballistic coefficient for your bullet.
Drag Curve - the Applied Ballistics custom drag curve, or the G1 or G7 standard projectile models.
Bullet Weight - the bullet weight measured in grains.
Bullet Diameter - the bullet diameter measured in inches.
Bullet Length - the length of the bullet measured in inches.
NOTE: You can find this information on the bullet manufacturer's website.
