Sending a MapShare Link From a GPSMAP 66i/86i/86sci
Depending on which feature you have enabled on your account, a LiveTrack™ page link or a MapShare™ page link can be sent to friends and family directly from an inReach® device after tracking has been started so that they may follow your progress. If you are using MapShare and have set a password for your MapShare page, the password is included automatically when you use the share feature from the website, the device or the mobile app.
NOTE: Before attempting to send your MapShare link, the MapShare feature should be enabled and configured in your inReach account. For assistance, see - Setting Up MapShare for the GPSMAP 66i/86i/86sci. For more details on LiveTrack, see - LiveTrack for inReach.
Sending a MapShare Link From a GPSMAP® 66i, 86i, or 86sci Outdoor Handheld
  1. Access the main menu by pressing MENU twice.
  2. Select Tracking.
  3. Select Send MapShare.
  4. Select Share.
  5. Select the To field, then select one or more of your contacts from the list or select Type Recipients.
  6. Press QUIT from the contact list, or select Done after typing recipients.
  7. Select the Message field to customize your message.
    • A default message of I'm starting my trip. Follow along here! will be pre-filled. You can edit or add to this message, if desired. A link to either your LiveTrack page or your MapShare page will be included with the message.
  8. Select Send Message.
Related
