How to Reset Montana 700 Series Device
There are a few instances in which it is necessary to perform a full reset on a Montana® 700 series outdoor handheld, including the following:
  • Not receiving a satellite signal
  • Restoring the factory default settings
  • Not functioning properly
The information and steps below will walk you through backing up your data and resetting.
Before Resetting
Performing a full reset can cause user data loss. User data is waypoints, routes, tracks, activities and geocaches.
It is recommended to back up important data with BaseCamp™ software before resetting. For steps, see Related.
Note: The Montana 700i, 710i, 750i, and 760i outdoor handhelds back up data to your Garmin Explore™ Website account via the Garmin Explore™ App. You can also back up data with BaseCamp software.
If removing data is desired to eliminate corrupt data or free up space, see Related.
Performing a Full Reset
  1. Power off the Montana
  2. Press and hold Power until the LED becomes red, then release
  3. Double-tap Power to start the reset
    • The screen will indicate it is resetting and display the progress, then shut off
  4. Power the Montana back on normally
  5. Select your language
    • The Montana 700i, 710i, 750i, and 760i handhelds will display the option to Activate or Skip, select Skip. You will then need to re-pair and sync with the Explore app
The Montana handheld is now reset and ready for use.
Related
