Alpha 10 Settings and Factory Resets
There are a few instances in which you may want to reset your Alpha® 10 to factory defaults, including the following:
  • Not receiving a satellite signal
  • Restoring the factory default settings
  • Not functioning properly
There are two types of resets within the Alpha 10:  one will retain paired devices and simply revert menus to defaults, the other will wipe all user entered data and settings back to factory defaults.
Resetting Menu Defaults or User Data and Settings
  1. Press Menu button
  2. Select Setup
  3. Select System
  4. Scroll down the list of choices and choose either
    • Restore Defaults
      • To restore all menu settings to back to default menu values. Saves all user entered information
or
    • Factory Reset
      • To Delete all user data and revert all values back to Factory settings
