Changing Map Themes and Colors on a Garmin Automotive Device
When a different Map Theme is selected, the colors used for various mapping items (e.g., background, major and minor roads, highways, etc.) change to more accurately reflect the colors which are generally used in the selected area.
To Change the Map Theme:
- Touch Settings
- Touch Apps first then Tools on some devices
- Touch Map & Vehicle or Map Display
- Touch Map Theme or Street Map Theme
- Select the desired Map Theme (a preview appears on the right side of the screen on some devices)
- Touch Save
The Map Theme will now be saved. Repeat these steps as needed.
