Showing Icons on the Map of an Outdoor Handheld
If you are not able to see icons for waypoints, points of interest (POI), or other items on the map of your outdoor handheld, you may need to adjust the zoom level at which map items appear. Map items do not appear when the map zoom level is higher than the selected level. To change this setting, refer to your specific handheld model below.
eTrex® 20, 20x, 22x, 30, 30x, or 32x Outdoor Handhelds
  1. Select Setup from the main menu.
  2. Select Map.
  3. Select Advanced Map Setup.
  4. Select Adjust Zoom Ranges.
  5. Select Zoom Levels.
  6. Select a category to adjust the zoom level at which it will appear on the map.
eTrex® Touch Series Outdoor Handhelds
  1. Touch Three Lines Menu Icon to open the Setup menu.
  2. Select Map.
  3. Select Advanced Setup.
  4. Select Zoom Levels.
  5. Select a category to adjust the zoom level at which it will appear on the map.
GPSMAP® 64 or 65 Series Outdoor Handhelds
  1. Press MENU twice to access the main menu.
  2. Select Setup.
  3. Select Map.
  4. Select Advanced Map Setup.
  5. Select Adjust Zoom Ranges.
  6. Select Zoom Levels.
  7. Select a category to adjust the zoom level at which it will appear on the map.
GPSMAP® 66, 67, or 86 Series Outdoor Handhelds
  2. Select Setup.
  3. Select Map.
  4. Select Advanced Setup.
Montana® 600, 610, or 680 Series Outdoor Handhelds
  1. Touch Up Arrow to open the Application Drawer.
  2. Select Setup.
  3. Select Map.
  5. Select Zoom Ranges.
Montana® 700 Series Outdoor Handhelds
  1. Touch Home to reach the main menu.
  2. Select Setup.
  3. Select Map.
Oregon® 600 Series Outdoor Handhelds
  1. From the main menu, open the Application Drawer by swiping: left to right (Landscape) -or- bottom to top (Portrait).
  2. Select Setup.
  3. Select Map.
Oregon® 700 Series Outdoor Handhelds
  1. Touch Three Line Menu Icon to open the Setup menu.
  2. Select Map.
  4. Select Zoom Controls.
Rino® 750 or 755t Outdoor Handhelds
  1. From the main menu, open the Application Drawer by swiping: Left to right (Landscape) - Bottom to top (Portrait).
  2. Select Setup.
  3. Select Map.
  5. Select Zoom Controls.
