STR3AMUP! Application - Creating an Overlay in the STR3AMUP! Application
Before you can use STR3AMUP!™ overlays, you must have a video streaming tool installed. The streaming tool must support external window capture and chroma keying.
You can customize the data, colors, and format of the biometric data overlay. You can also customize graphical overlays that appear when your biometric data passes a configurable threshold.
  1. From the main screen, select your overlay settings.
    Application main screen with callouts
    Callout number one
    Select which biometric data to enable on the overlay.
    Callout number two
    Customize your preferred layout and colors for the biometric data.
    Callout number three
    Select Left or Right to select an overlay icon for your metrics. Select Up or Down to set the threshold value when the icon appears.
    NOTE: You can activate sound effects and video filters of third-party tools using hot keys tied to the biometric data thresholds. To use these effects, select the hot key button in the STR3AMUP! application, and set up the same hot key in your third-party tool.
    Callout number four
    Select Checkmark to enable the animated window frame. You can customize the size and color of the frame.
    Callout number five
    Preview your selected overlay features.
    Callout number six
    Select to change the preview background color from light to dark.
    Callout number seven
    Select to enable the Powered by Garmin® design.
  2. When you are finished selecting your settings, select Create Overlay.
    A green window appears for each overlay, and the controls window allows you to manage the settings.
  3. Position the overlay windows where you want them in your streaming tool.
  4. When you are done positioning the windows, disable the preview setting in the controls window.
    The overlay windows display data when you exceed the thresholds.
  5. Use your streaming tool to capture the overlay window content.
    TIP: For each of your overlay windows, you should verify that the STR3AMUP! source is visible to your streaming tool and the window titles match.
  6. In your steaming tool, use the chroma key or color key filters to make the green background of the overlay windows transparent.
