How Do I Adjust the Time on the vívomove HR?
The vívomove® HR watch receives the time that it displays from either the Garmin Connect™ app on a smartphone or from Garmin Express™ on a personal computer. To update the digital time, sync your device using your preferred method.
The Time on My vívomove HR Is Still Wrong After Syncing
This would indicate that the time setting on the device is set to Manual instead of Auto. To correct this issue, take the following steps:
Wake up the display on the watch and swipe the touchscreen.
Hold the touchscreen to view the menu.
Select
Select
Select Set Time.
Select Auto.
If the time was set to Manual, perform another sync. This should correct the time on your device.
The Watch Hands on My vívomove HR Are Off
You can adjust the hands to match the digital time on the watch by following these instructions: How Do I Align the Watch Hands on a vívomove Series Watch?
