My vívofit 3 Will Not Turn On
If your vívofit® 3 watch will not turn on it may need the battery replaced. For detailed instructions on how to replace the battery, see vívofit 3 Battery Replacement. If the watch shuts off shortly after replacing the battery, ensure that the gasket is not damaged and it is fully seated in the rear case.
NOTE: You will need to re-pair the vívofit 3 to the Garmin Connect™ app after replacing the battery. For more information, see Remove and Add a Device From the Garmin Connect App.
