Diver Certifications in the Garmin Dive App
You can add all of your diver certification information, including uploading pictures of your certification cards, to the Garmin Dive™ app so that everything is stored in one convenient location. You can also have the certifications automatically added to new dives completed after entering the information.
Adding a Diver Certification
Open the Garmin Dive App.
Select
Select Diver Certifications.
Select Add a Certification if you are adding your first certification.
For subsequent certifications, select the
plus icon in the upper right.
Enter your certification information.
TIP: When entering your certification date, you can tap the year at the top of the calendar to select the appropriate year. Use the arrows to scroll through the months.
Select Save in the upper right.
Editing or Removing Diver Certifications
Select
Select a certification.
Select
in the upper right.
Select an option:
Edit - allows you to edit that certification.
Duplicate - copies the information into a new certification that you can edit if you received multiple certifications from the same agency or dive shop.
Remove - deletes the certification entry.
