Frequently Asked Questions About the Garmin Clipboard App
The Garmin Clipboard™ Team App allows Coaches to better track their athlete data by showing it all in one location on a compatible smartphone or tablet.
Select a topic below to learn more:
First Time Setting Up Garmin Clipboard Coaching App as a Coach
Can I Use the Garmin Clipboard App for an Athlete and Coach Profile?
What Activity Profiles Are Available in the Garmin Clipboard App?
Selecting Sign In allows you to use an existing personal Garmin Connect™ account. While selecting Create Account allows you to create a new account if you would like to use a different email address or do not have an existing Garmin Connect account.
Once you have signed into your Garmin Clipboard account, select I am a Coach.
Create a Profile by adding your Name & Profile Picture.
Select Next.
Select Continue.
Create an Organization
Continuing on from the steps you completed above:
Select + New Organization.
Enter an Organization Name.
Select Organization Colors.
Add an Organization Image (optional).
Select Save.
Create a Team
Select Create Team.
Enter a Team Name.
Select the Team Sport.
Select Save.
Share With Your Athletes
You will receive a QR Code to share with your athletes.
Select Share and proceed.
Select Done when you are finished.
Select Continue.
You will now be at the homepage for the Clipboard App.
How Do I Add Additional Coaches?
Open the Garmin Clipboard app.
From the Homepage, select the name of your Organization.
Under Coach Rosters select + Invite.
Select Share.
Send through your phone's contacts.
Once the added Coach accepts the invitation they will be added to the Coach Roster under the selected Organization.
How Do I Add Athletes to a Team?
NOTE: For best app performance, do not add more athletes to your team than is necessary.
From the Homepage, select the Team Name.
Select
(top right).
Select Invite Athletes.
Select Share.
Complete the share using your Phone settings.
Once the invitation is accepted, return to the Team Page.
Select Assign Existing.
Select the Athletes.
How Do I Manage the Roster?
Select the Team you want to edit the roster for.
Select
next to Athlete Roster.
Select Manage Roster.
You can now remove or edit athletes on the team or view data shared for the roster.
How Do I Add an Announcement for the Athletes to View?
Select the Organization.
Select the Team.
From the Team Dashboard, Select Add Announcement.
Enter your announcement.
Select Save.
Athletes will receive a notification that an Announcement has posted to their team.
How Do I Send Workouts to My Team?
Access the Menu.
Select Workout Library.
Select the Workout from:
My Library
Search Garmin Library
New Workout
Preview the workout.
Select Schedule Workout.
Add Athletes.
Select Date.
Select Post.
Athletes will now be able to see the scheduled workout in their calendar using the Garmin Clipboard app. Once they select the workout, they can select Send to Device.
How Do I Manage My Workout Library?
Create a Workout
Select New Workout.
Select an Activity Type.
Enter a Workout Name.
Select a Step Type.
Select an Exercise.
Select a Duration type.
Enter an exercise weight (optional).
Enter a Step Note (optional).
Select Done.
Select Add Step and repeat steps 5-9 to create the full workout.
Select Save.
Now that you have a workout created, you are ready to schedule the workout for your athletes.
Schedule a Workout
Select the workout you wish to send.
Select Options.
Select
to add your Athlete(s).
Choose one of the following:
Toggle Repeat On to schedule a workout repeat interval.
Toggle Repeat Off to schedule the workout on a certain date.
Select Post.
The workout has been posted in the calendar of your selected athletes. Your athletes can then sync the workout directly to their Garmin® device, see: How to Send Workouts to a Garmin Device for instructions.
Delete a Workout
Select the workout you wish to delete.
Select Options.
Select Delete.
Select Delete to confirm.
Your workout has been deleted and will no longer appear in your Athlete's calendar.
How Do I Add Thresholds to the Athletes Training?
(top right).
Select Threshold Settings.
Select the name of the setting you want to enable settings for.
Those that are enabled will have a Check-Mark to the left.
Select Edit on each Setting that you have enabled.
Edit the threshold and select Apply.
Once you have finished editing all threshold settings select Save.
First Time Setting Up Garmin Clipboard as an Athlete
Selecting Sign In allows you to use an existing personal Garmin Connect account. While selecting Create Account allows you to create a new account if you would like to use a different email address or do not have an existing Garmin Connect account.
Once you have signed into your Garmin Clipboard account, select I am an Athlete.
Select Create a Profile.
When prompted to link Garmin Clipboard with Garmin Connect make sure you have the following toggled on
so that your Coach can access your information for training:
Activities
Daily Health Stats
Training
Select Save.
Select Agree.
Manage Profile by adding your Name and Profile Picture.
Select Update.
You will now be at the Garmin Clipboard Athlete Homepage.
NOTE: After setting up your Clipboard app, the last 14 days of data will automatically transfer to the app. If your Coach is not able to see your uploaded activities it may be due to Privacy Settings not being set properly in the Garmin Connect account. Ensure your activities are not set to "Only Me". To check these, please see Adjusting Privacy Settings in Garmin Connect.
You can swap between your Coaching profile and your Athlete Profile at any time by following the steps below based on the current active profile:
From the Athlete Profile:
Select your Profile Icon (bottom right).
Select
for Settings.
Select Accounts.
Select Switch to Coach Dashboard.
If you have not setup your Coaching Profile yet, walk through the on-screen prompts to setup your Coaching Dashboard.
From the Coaching Profile:
Select
for Settings (top right).
Select Accounts.
Select Switch to Athlete Portal.
If you have not setup your Athlete Profile yet, walk through the on-screen prompts to setup your Athlete Dashboard.
What Team Sports Are Available When Creating a Team?
Baseball
Basketball
Beach Volleyball
Bowling
Cross Country
Fencing
Football
Golf
Gymnastics
Hockey
Ice Hockey
Lacrosse
Rifle
Rowing
Running
Skiing
Soccer
Softball
Swimming/Diving
Tennis
Track and Field
Volleyball
Water Polo
Wrestling
Other
Running
Cycling
Gym & Fitness
Swimming
Walking
Hiking
Motorcycling
Diving
Winter Sports
Racket Sports
Team Sports
Water Sports
Rowing
Indoor Rowing
NOTE: Coaches can filter which activities are displayed in the athlete portal by tapping on the 3 dots above the activity calendar.
How Do I Change the Unit of Measure?
Access the Menu.
Select
Select Measurement Unit
Select your preferred unit of measure.
How Do I Add Compliance Days?
Compliance Days in the Garmin Clipboard™ coaching app will block activity data from being viewed by the coaches. To add or edit compliance dates, see the steps below:
Select your Team / Organization.
Select
(top right).
Select Edit Compliance Days.
Select the dates.
Select Save.
The dates selected will no longer show any activity data for the Coach to view.
