Using Waypoint Notes in the Garmin Explore App
The Garmin Explore™ app allows you to add notes to waypoints to help you remember why you wanted to save them (e.g. waterfall or turn left at this sign). Keep in mind that these waypoint notes will only be displayed in the Garmin Explore app and on select Garmin handheld devices when they have been synced with the app. The following handheld devices have the ability to view, edit, and sync waypoint notes with the Garmin Explore app:
  • eTrex® SE | eTrex® Solar
  • GPSMAP® 64s | GPSMAP® 64csx | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx
  • GPSMAP® 65 | GPSMAP® 65s
  • GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
  • GPSMAP® 67 | GPSMAP® 67i
  • GPSMAP® 86i | GPSMAP® 86s |GPSMAP® 86sci
  • Montana® 700 | Montana® 700i | Montana® 750i
Waypoint notes cannot be added, edited, or viewed on the Garmin Explore website. When exporting waypoints directly from the Garmin Explore app, waypoint notes will not be saved in the exported GPX files. Alternatively, waypoint names can also be edited if there is information that needs to be viewed in other apps or programs.
Editing Waypoint Notes and Waypoint Names
  1. Open the Garmin Explore app.
  2. Select  Bookmark Symbol Saved.
  3. Select the waypoint you wish to edit.
    NOTE: If the waypoint you wish to edit is in a collection, swipe left or right under Collections or select View All, select a collection, then select the waypoint you wish to edit. You can also scroll down to All Items and select Gray Waypoints Icon to access any saved waypoints.
    Garmin Explore App Saved All Items
  4. Select Edit.
  5. Select an option to edit:
    • Select Details, then tap on the NOTES field to add or edit waypoint notes.
    • Tap on the name of the waypoint to edit the name.
      Name and Notes Fields
  6. Select Save.
Related
