Getting Started With Tracking in the Earthmate App
The Earthmate® app is the companion mobile app for your compatible inReach® handheld. Tracking is the uploading of your position coordinates so others can follow your trip progress via your MapShare™ page. Tracking requires an active inReach satellite subscription to function and may be started either on the inReach device or with the Earthmate app. For steps on setting up MapShare, see - Setting up MapShare in the Earthmate App.
IMPORTANT: With the Safety,1 Essential, and Enabled plans, there is an additional cost per point (varies by currency) using the Send/Moving Interval. As an example, if your Send/Moving Interval is set to 10 minutes and you had tracking on for 1 hour, you could be charged for 7 track points (this includes a starting track point). For more details, see - Understanding Charges for Tracking on inReach Safety, Essential, and Enabled Plans.
Tracking With the Earthmate App
Tracking can be started in the app with or without an inReach device actively paired. However, track points will only be sent to your MapShare page via satellite when an inReach device is actively paired.
Tracking With a Paired inReach Device on Android™
When an inReach handheld is actively paired, changes made to tracking (starting, stopping, track settings) in the Earthmate app will also reflect on the paired inReach handheld and track points will be sent to your MapShare page via satellite.
Starting Tracking in the Earthmate App
  1. Open the Earthmate app.
  2. Touch Three Lines Menu Icon to open the menu.
  3. Touch Tracking.
  4. Touch Start.
Tracking will then start in the Earthmate app and on the paired inReach handheld.
When tracking has been started, the track line and send points can be viewed on the map in the app. Tracking settings for the connected inReach handheld can also be adjusted through the Earthmate app.
Tracking Settings
  2. Select three dots.
  3. Select Settings.
  4. Select Tracking.
  5. Select an option:
    • Select Send Interval to change the frequency at which the connected inReach device records a track point and transmits it over the Iridium® satellite network when you are moving.
      NOTE: This setting is called Moving Interval when using an inReach SE® satellite communicator with the app, or Interval when using inReach Original devices (inReach for Android, inReach for PN-60w, inReach for Smartphones).
    • Select Log Interval to change the frequency at which the connected inReach device logs your location and updates the track line in the device's memory when you are moving.
      NOTE: This setting is not available when using an inReach SE satellite communicator or inReach Original devices (inReach for Android, inReach for PN-60w, inReach for Smartphones).
Example of Tracking in the Earthmate App With a Paired inReach Handheld
The log points show as a blue line and the send points show as yellow dots.
Earthmate for Android Track Example
NOTE: While actively tracking, the tracking page only shows a straight line between the yellow send points. To view the detailed log interval line while actively tracking, switch to the map page.
Tracking With a Paired inReach Device on iPhone®/iPad®
  2. Touch Tracking.
  3. Touch Start.
Tracking Settings
  2. Select More.
  3. Select Options.
  4. Select Tracking.
Earthmate for iOS Track
Tracking Without a Paired inReach Device on Android
The Earthmate app can use your mobile Android device's GPS for tracking when an inReach handheld is not paired, but track points will not be sent to your MapShare page via satellite.
  3. Touch Tracking.
  4. Touch Start.
  5. Touch Use Smartphone GPS.
Tracking will then start in the Earthmate app using the mobile device's GPS.
Tracking Without a Paired inReach Device on iPhone/iPad
The Earthmate app can use your iPhone or iPad's GPS for tracking when an inReach handheld is not paired, but track points will not be sent to your MapShare page via satellite.
  2. Touch Tracking.
  3. Touch Start.
  4. Touch Use iPhone/iPad GPS.
1 The Safety subscription plan is no longer available for purchase. The Safety plan has been replaced by the Essential plan.
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
