Extending the Fusion® Apollo™ MS-ERX400 Network/Power Cable
The Fusion® Apollo™ MS-ERX400 Network/Power Cable is a 26 foot cable that comes with the MS-ERX400 Wired Remote. If necessary, this cable can be extended in 1 of 2 ways.
A Garmin Marine Network Cable (Small Connector) is a 20 foot cable that can connect to the port on the back of the remote. Then a Cable Coupler for Garmin BlueNet™ Network can be used to connect the Network/Power Cable to the other end.
The other way to extend the cable is to use a Garmin Marine Network Cable Coupler to connect to the end of the Network/Power Cable. Then, connect the Fusion Shielded Ethernet Cable to the other side of the coupler. The Fusion Shielded Ethernet Cable is an Ethernet cable that comes in lengths of 20, 40, and 65 feet.
