1. Click on your device. The green dot means Garmin Express recognizes the device
2. Click Add a Device and follow the on-screen steps to add a new device
3. A message may appear asking if you want to replace the first device if you're adding a second device of the same model.
Select Yes if this is a replacement device.
Select No if you have two devices of the same model.
Garmin Express will display the updates. Your device may have a software update available, a map update available, or both. You will have an option to “Update Software,” “Update Maps,” “Install,” or “Install All.” Each path begins with this selection.
NOTE: Your device may require a software update before installing a new map. In this case, the software update will be installed before returning you to this screen where you will then have the option to “Install All” or “Update Maps.”
4. Click Update Software, Update Maps, Install, or Install All
Clicking View Details allows you to see a list of available updates and install them individually.
Garmin recommends clicking the option in the blue button to ensure all updates are installed.
5. Read the notes and click Continue
Garmin Express will display the current progress.
6. You may be prompted to restart your device if software updates are installed. Garmin Express will display instructions.
7. Click Install All or Update Maps if you have a map update available.
NOTE: See
Space Issues when Installing Map Updates
if the desired coverage area is not offered.
8. Read the Terms and Conditions and click Accept
9. Read the notes and click Continue
Garmin Express will display the Map Update progress.
An “Updates complete” message will appear when the map update finishes.
Back to top
Note: Disconnecting the device or shutting down the computer before the update completes will cause an error and may make the device unusable.
