Remove and Add a Garmin Dive Computer in the Garmin Dive App
There may be times you need to remove your Garmin® dive computer and add it back into the Garmin Dive™ app. Examples are Bluetooth® connection issues or replacing the device.
NOTE: Removing the device from the Garmin Dive app will automatically remove it from the Garmin Connect™ app. For Garmin watches that support a Garmin Pay™ wallet, if you have created a wallet on your watch, the wallet will be deleted. You will need to recreate your Garmin Pay wallet once you have added your device back to the app.
Removing a Garmin Dive Computer in the Garmin Dive App
These instructions are the same for both Android™ and Apple® devices.
  1. Open the Garmin Dive app.
  2. Select More (bottom right).
  3. Select Garmin Devices.
  4. Select your device.
  5. Select Three Dots Option.
  6. Select Remove Device.
  7. Select Remove from the pop-up box to confirm.
    IMPORTANT: The device will still be paired in the Bluetooth settings of the smartphone. You will need to remove the device from these settings as well. Settings vary based on the model of your phone. Consult your phone's owner's manual for specific steps.
Your device is now removed from the Garmin Dive app and your phone or tablet's Bluetooth settings.
Adding a Garmin Dive Computer in the Garmin Dive App
These instructions are the same for both Android and Apple devices.
  4. Select Add Device.
  5. Place your dive computer into pairing mode. Refer to your owner's manual for specific steps.
  6. Select Connect It when your device is found.
  7. Enter the code from the face of the device.
  8. Follow the onscreen prompts to complete the pairing.
Your device and the Garmin Dive app are now paired.
