Flashing Yellow/Yellow or Yellow/Green Light on a Garmin Dash Cam
Garmin Dash Cam™ Mini 3, Garmin Dash Cam™ Mini 2, Garmin Dash Cam™ Mini driving recorders will have different LED status light colors and sequences that mean different things. For a full breakdown of this see:
- Understanding the LED Colors on the Garmin Dash Cam Mini 3
- Understanding the LED Colors on the Garmin Dash Cam Mini 2
Flashing yellow/yellow or yellow/green lights indicate there is an error related to the memory card or a memory card is not installed.
Garmin Dash Cam Mini 3:
Garmin Dash Cam Mini 2:
Garmin Dash Cam Mini:
Check the Following in This Situation:
Ensure the memory card is pushed in all the way
- For help refer to your owner's manual and search for “Installing a Memory Card”.
Format the memory card
Verify a compatible memory card is being used
See SD Memory Card Compatibility for Garmin Dash Cams for more information
A different compatible memory card may need to be used if the problem continues.
